changing grips
06-18-2008, 12:18 PM
changing grips
any advice for changing bar and grip on a nightster
06-18-2008, 02:07 PM
RE: changing grips
take razor, cut off old ones, slide on new ones... DONE, if you are using rubber grips to replace the stock, use hair spray to lube if your going to metal use superglue gell
06-18-2008, 02:44 PM
RE: changing grips
Lay a thick towel over your tank to protect it.
06-18-2008, 07:53 PM
RE: changing grips
Avoid fancy grips that will create pressure points on your hands. \\; Gets old after awhile.
06-18-2008, 09:46 PM
RE: changing grips
very easy cut them off slide new ones on ,did it monday night
[IMG]local://upfiles/41293/C365D20040D945148175D4E41E55AA74.jpg[/IMG]
MattCo
08-11-2012 09:13 AM
SoCal Harley
10-22-2011 12:19 PM
mikehoius
04-09-2011 02:22 PM
hockey8787
02-24-2011 11:54 PM
jbhawley
04-26-2007 09:30 AM
