2 up riding on 883l
Old 06-19-2008, 05:45 PM
tcman2006's Avatar
tcman2006
tcman2006 is offline
3rd Gear
Default RE: 2 up riding on 883l
would the stock shocks be ok if u set a preload. also im not sure if i should get a new seat( badlander) or just a passenger pillon? i have no clue. Has anyone ever used the harley 2 up shocks u can get?
Old 06-19-2008, 06:43 PM
Handycam's Avatar
Handycam
Handycam is offline
ORIGINAL: Zimbob
the stock shocks are fine for now. Set up the preload some and you'll be ok.
How do you adjust the stock shocks? I ride solo, but on some roads they bottom out on me and my spine cringes.
Old 06-19-2008, 08:42 PM
Werbeck's Avatar
Werbeck
Werbeck is offline
You can buy a "spanner wrench" at the dealer for about 12 bucks, probably cheaper anywhere else. But anyway, with your spanner wrench it's super easy to raise or lower your shocks. When I take my wife I set the shocks to their highest, or stiffest setting. When I go back solo I lower them full down.
You can ride two up with the stock shocks OK but the the Progressives will keep you from bottoming out as often and give a little extra cushion to your ride.
Old 06-19-2008, 08:49 PM
Handycam's Avatar
Handycam
Handycam is offline
Do you mean a British "spanner" aka the U.S. "monkey wrench" aka adjustable wrench? Or something more specialized?
And what gets tightened/loosened, exactly? I am new to tinkering.
Thanks.
Old 06-19-2008, 08:53 PM
.T.'s Avatar
.T.
.T. is offline
ORIGINAL: Handycam
Thanks.
&nbsp\\;
The spanner wrench looks like a claw and adjusts the preload of the spring at the bottom.
Old 06-19-2008, 09:19 PM
Handycam's Avatar
Handycam
Handycam is offline
Ah, thanks. I just googled it, seems like there are several types. Some are hook shaped and some are hinged like scissors.
What's the procedure for increasing the preload?
Old 06-19-2008, 09:27 PM
tcman2006's Avatar
tcman2006
3rd Gear
i got an 883l and i think&nbsp\\;there is four setting on the bottom of the shock right under the spring just turn it up the the next setting when u get to the highest turn in one more time and it will go back down to the lowest one
Old 06-20-2008, 12:06 AM
twisty571's Avatar
twisty571
twisty571 is offline
ORIGINAL: Sick1200
As far as things to do to you 883......1200 conversion!
Dude why? I ride 2 up all the time on my 883. We live in the mountains and travel twistys all the time?We have been all day riding no real issues as far as power.
Old 06-20-2008, 12:38 AM
HDXXX's Avatar
HDXXX
HDXXX is offline
We ride two-up all the time with a preload number 4 out of five with no problems.&nbsp\\;The railroad tracks are the only thing we worry about. The 412's are the way to go, but if you don't want to spend the money like me the stock will work.
ib5150
02-18-2015 09:37 AM
ebeattie
06-19-2013 01:21 AM
cnbcook
03-21-2013 11:18 AM
OldSchoolZ
01-02-2013 10:58 AM
yorgo
10-28-2009 07:31 AM
Quick Reply: 2 up riding on 883l
