Risers
Risers
Looking at these http://www.denniskirk.com/jsp/produc...00002. \\; Would I run into problems with the speedo hitting the tank or should I look at these insead \\;http://www.denniskirk.com/jsp/produc...00002. \\; Both say the stock top clamp can be used.
RE: Risers
2 1/2" pullback
http://www.denniskirk.com/jsp/produc...;mmyId=7600002
3 3/4" straight
maybe this will work
3 3/4" straight
RE: Risers
Here's my question. \\; DK has 2 1/2" pullback risers that supposedly will take the stock top clam from an 883C. \\; Will this be too short and make the speedo hit the tank? \\; They also have 3 3/4" straight risers that take the stock clamp. \\; Clearance shouldn't be an issue with the straight but I think my mini apes will look better with the shorter riser. \\; What's the shortest pull back any ons put on an 883C?
RE: Risers
That's another thing I am afraid of. \\; I know it's an odd riser/clamp design. \\; According to Denis Kirk, these will take the stock clamp. \\; I did go to the Drag Specialties site and their listing says they will not work with the 883C. \\; I guess if I want to change them I will need a new top clamp and alternate speedo mount as well. \\; Still, what is the shortest pullback I can put on, or If going with a straight riser, what are my speedo mounting options using my current speedo and indicator lamps?
RE: Risers
When posting urls especially long ones try using this
http://*******.com
Keeps long urls short and does not leave out \\;part of the urls like it did in your links here.
Danny
http://*******.com
Danny
ZeroFiveFour
07-24-2008 12:05 PM
