ASP 500 Error?
ASP 500 Error?
Anyone know what the following means?
Besides not being able to post 90+ percent of the time, as of today it's taking over a minute to even open a Forum or Thread, and most of the time I get the below message (on top of the 'Webpage Can't Be Found' message)\\;
I'm a patient person, but even so....
I hate to post this in the Sportster Forum, but it appears that it's the only forum in which a post will work, at least part of the time.
ASP 500 Error
Program File Name
/post.asp
COM Error Number
-2147467259 (0x80004005)
Error File Name
/includes/afu.asp
Line Number
156
Brief Description
[DBNETLIB][ConnectionWrite (send()).]General network error. Check your network documentation.[/align]
pxlSiteFile = "hdforums.com.js"\\; pxlScriptStart = '%3Cscr' + 'ipt type="text/javascript"'\\; pxlScriptEnd = '%3C/scr' + 'ipt%3E'\\; if (location.protocol.indexOf("https") == -1) { document.write(unescape(pxlScriptStart + ' src="http://pxl.ibpxl.com/'+pxlSiteFile+'"%3E'+pxlScriptEnd))\\; } else { document.write(unescape(pxlScriptStart + ' src="https://pxlssl.ibpxl.com/'+pxlSiteFile+'"%3E'+pxlScriptEnd))\\; }
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.")\\;document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"))\\;
var acct='UA-939292-2'\\;var ggIntvl\\;function loadGoogleFunctions(){if (typeof(_gat) == 'undefined'){ return\\; }\\; var pageTracker = _gat._getTracker(acct)\\; pageTracker._initData()\\; pageTracker._trackPageview()\\; clearInterval(ggIntvl)\\; ggIntvl = null\\;}\\;if (typeof(_gat) == 'undefined'){ggIntvl = window.setInterval("loadGoogleFunctions()", 200)\\;}else { loadGoogleFunctions()\\; }\\;
_qoptions = { tags:"Automotive" }\\;var _qacct="p-f3Hr4xDGnlZIE"\\;var qIntvl\\;function loadQFunctions(){if (typeof(quantserve) == 'undefined'){ return\\; }\\;quantserve()\\; clearInterval(qIntvl)\\;qIntvl = null\\;}\\;if (typeof(quantserve) == 'undefined'){qIntvl = window.setInterval("loadQFunctions()", 200)\\;}else { loadQFunctions()\\; }\\;
ASP 500 Error
An error occurred processing the page you requested.
Please see the details below for more information.
[align=center]Please see the details below for more information.
Program File Name
/post.asp
COM Error Number
Error File Name
/includes/afu.asp
Line Number
156
Brief Description
RE: ASP 500 Error?
I googled asp500 and seen this link its a start.
http://www.hostmysite.com/support/pr...ing/500-error/
Give that a try and google what ever there solution is for a fix.
good luck
good luck
