DIY Pipes or Slip ons...
RE: DIY Pipes or Slip ons...
I did the V&H Straight Shot slip on’s – very easy and straight forward – excellent instructions (obviously not written by HD).
+1 on the penetrating oil to get the old mufflers off.
I also rejetted the carb & installed the K&N airbox / velocity stack & filter. The difference in performance was startling. Like HUGE. It really woke up when I added a Daytona programmable ICM – WOW!
Some observations on the Straight Shots:
First - They are significantly louder than OEM mufflers. At first I was a bit concerned, but over time (couple of weeks) they calmed down after the guts got a nice even coat of carbon (that or my hearing was damaged) They are still loud, but manageable enough to keep the neighbors from vapor locking over the noise.
Second, after you install them and go out – come back let everything cool and then retighten all the bolts / nuts. You may need and it wouldn’t hurt to do this a couple of times. The heat cool cycles will loosen some things.
Last – get a new set of cross over pipe gaskets – save the headache of an exhaust leak.
I found my Straight Shots new on eBay from a dealer - $208 delivered.
My .02
My .02
No other mods needed just for slip on mufflers. I've done several of these installs. I usually find it easier to go ahead and take the entire exhaust off the bike. This allows for getting a better grip to get the mufflers to "slip off" I use plenty of WD-40, and application of a rubber mallet around the joint to help get the mufflers off.
Some are fairly easy, and some can be a real pain to get the muffler off. Mine was a ROYAL pain, but I've done others that weren't too difficult. Either way, it's a simple straight forward install. Just sometimes difficult to get the original mufflers to let go.
Received 18,236 Likes
PB Blaster and others like it, Liquid Wrench, Break Free, are sprays that break up and loosen rust. Good to have some on hand as lots of bolts will end up needing it over time. Also spray the nuts for the clamps that clamp the muffler to the pipe, and the cap nut that holds the rear header pipe to the engine. I have farted with mine so many times I can swap mufflers in about 15 min, by myself. If you are doing this by your self, like I do, you will be well served to use a board or a covered bar (to prevent scratching the frame) to wedge between the front header pipe and the frame, to keep it from ripping loose as you pull backwards. I usually put my foot against the bar, while lifting the muffler off the crossover bung and pulling backwards. Its a kind of dance, to do it all at the same time. Best if someone holds the front header for you, at least the first time.
For the rear, I usually TRY to leave the aforementioned mount bolt (rear header to engine) connected but very loose, to allow the same lift, wiggle, pull dance for the rear muffler. The crossover pipe is under the mufflers and hidden from normal view.
It should go without saying, in my opinion, do all this when the bike is cold, or the mufflers anyway.
Gool luck, let us know how it goes.
Anyone here done a DIY with pipes or slip ons? I'm thinking about the V&H Short Shots or the Straight Shot slip ons (can't decide what would look better). I read their PDF and it LOOKS pretty straight forward. I'm just looking for some feedback or maybe some personal experiences on DIY- what to look out for, trouble spots, tricksetc. etc.
Thanks
Thanks
