rocker cover gasket leaking
Old 05-30-2008 | 11:08 AM
wilburz's Avatar
wilburz
Default rocker cover gasket leaking
i think my lower rocker cover gasket is leaking.
Should this repair be covered under my 2 year factory warranty?
Old 05-30-2008 | 12:53 PM
OldFenderGuy's Avatar
OldFenderGuy
Default RE: rocker cover gasket leaking
Should be covered by the 2 year warrantly.
The dealership should consider any oil leak a serious issue, and not try to jerk you around.
If the leak continued it could become worse, causing fluid to accumulate on the frame, and maybe even end up getting blown back on your rear wheel.
Old 05-30-2008 | 01:54 PM
ecaldwell78's Avatar
ecaldwell78
+1 OFG hit the nail right on the head. Aside from the leak, there is a huge liability issue here. Don't let 'em blow any smoke up your **** either. They either fix it....or....they fix it. PERIOD
Old 05-30-2008 | 02:06 PM
wilburz's Avatar
wilburz
good info. thanks. its not leaking real bad but you can see it collecting on the jug and on the battery cover.
jambo1989
11-20-2016 10:56 AM
tloc1000
05-26-2015 02:44 PM
bmaier
05-25-2015 10:07 PM
texasridr
EVO
17
06-06-2009 11:20 PM
rhomer
09-07-2007 10:00 AM
