m6 help
m6 help
Trying to install a M6-XL5-2 on the wifes 04 1200C. The directions state the the tall side of the GUIDE PLATE should go between the the chain and the case (which I take to mean chain and engine). It will not fit that why. I put the primary cover on the bench and still couldn't get the bolt thru the assembly without it being totally cockeyed. If you turnthe guide platearound it goes together fine. But the directions say TALL SIDE BEHIND CHAIN TOWARD CASE in bold letters. Any help would be greatly appreciated
Ken
Ken
RE: m6 help
It looks like you have it correct, the tall side of the guide plate goes between the chain and case, NOT the chain and cover.
http://www.haydensm6.com/pdf/xl5-2.pdf
The FAQ sheet (Item 2) mentions the possibility of needing to grind the guide plate. I'm not sure this applies to your situation though.
http://www.haydensm6.com/faqs.htm
Sounds like a PITA.
Sounds like a PITA.
RE: m6 help
I don't think they are refering to the adjuster for the 04 Sportster with regards to grinding. And if they are that would make this thing a real POS. The area where there is interference is where the "legs" are. If you have to grind them...what does it stand on?
Thanks for the reply
Ken
Ken
RE: m6 help
Definitely calling Tues. Now I see there are two adjuster for the late modelSportster. M6-XL5, says its for 91 & up 5 speed Sportsters. The M6-XL5-2 (which I have)says it's for 04 and up 5 speeds Looking at the pics the only difference I see see is the XL5-2has "legs" on the base. The legs are what interfere with the cover
RE: m6 help
I got one and I installed it at my dads house like they said and it was about 5 miles down the road I stopped at my house and the primary was making a noise. I pulled the cover off andthe adjuster had fell off the bolt that holds it in. I reinstalled it with the long side facing the primary cover and ive been riding it like that for a few weeks now. That metal piece just seems to fit that way a lot better and its alot easier to put back togetherlike that.I tried calling customer service about it and never could get through to ask them about it.
RE: m6 help
ORIGINAL: sidewayzls1
thanks
Ken
RE: m6 help
I just got off the phone with Hayden. They said it doesn't matter which way you install the guide plate. They said they were updating their instruction sheet
Well, I got it installed. Took it out for a test run...seems to shift much smoother, but I don't ride that bike much so I'll have to wait for the Mrs. to give me her opinion
