Auxiliary Lighting not working
I have this in the elec. section but no responces yet. I have the Auxiliary Lighting Kit on my sportster. This mourning on my way to work I was behind a truck and noticed that they were not working. I pressed the switch and still not working. Where do I need to start to troubleshoot this? Blinkers and main head light and bright are working fine.
RE: Auxiliary Lighting not working
There is no simple/single answer since the aux lights can be hooked up serveral ways. Do your's have a seperate switch for turning them on/off of are they controlled by the hi/low headlight switch? They should also be powered by a seperate circuit with an in-line fuse. If they are controlled by the hi/low headlight switch there should be a relay in the circuit that you should check.
Ok thanks. I did take a quick look at lunch and traced the wires back and they went somewhere behind the battery. Atlest I'm on the right track. I'll have to remove the seat and battery at home to really see where it goes. Since I was at work I really couldn't see where it went.
i would first pull off the headlight bucket and see how they are wired up... i know most people will tap it off the main line to the headlight that way when you click your brights they go off... as was said, many people do this diff... the fuse shoudl prob be in the headlight bucket...
ORIGINAL: JRK5892
Ok did alittle looking around. When I click a on/off switch that is mounted. I can hear a clicking. I bleve comeing from this relap in the picture. I took the relay out added deciling electronic grese to it. Don't hear the clicking nomore. From my on off witch that cutts the Aux lights on or off I traced two wire to two different locations. Here are bout of the picks. The part number on the relay from the pic is m923006 if this helps any. Still not working.
Wire one:
Relay pic wire 2
Wire one:
Relay pic wire 2
