new rider needs some advice
i just picked up an 03 sportster 883 and im not sure if its running properly. most of the time, it seems to run great, but it feels like at high speed, part throttle like it misses sometimes. ive heard that aftermarket pipes can cause a backfire at part throttle due to a lack of backpressure and a buildup of fuel in the cylinders, but it doesnt really feel like a backfire, nor does it sound like one. the guy i bought the bike from said he put aftermarket pipes on it, but couldnt remember what kind they were and i dont know. also, it smells like its running really rich at idle, though it idles great. i pulled the plugs and looked at them, they look like they have a fair amount of carbon build up on the insulator. would changing the plugs help or should i look into rejetting the carb. the last thing is there is alot of oil coming out of the carb. anyone have any ideas/advice? thanks in advance.
RE: new rider needs some advice
The oil thing is normal, all sportsters do it, just some more than others. There are several "fixes" for it. do a search. Yes, change the plugs and do not lug the motor, sportsters like the rpm's up more than the big twins do. Question; when you warm up the motor, do you use the choke ? If you do, stop it. Only use the choke to get it started, then use the star wheel under the right grip to hold the rpm's up with the choke off. Hold the rpm's about 1000 to 1200 rpm while she warms up. That will help with the keeping the plugs from getting fouled like you are describing.
If you are noticing any electrical problems too...like the spedometer needle jumping more than it should or the digital guages clicking on and off.....then check the battery cables to make sure they are making proper connection. sometimes if they wiggle around and don't make good connection, you'll get the back/misfire feeling/sound.
ORIGINAL: Zimbob
As for the oil blowby,check the level as you may have it a little full.The level should only be about 1/3rd above the low mark. Clean or replace the filter.For the hesitation, it could be a number of things....Add some seafoam to your next tank full. You don't say how long the bike has been sitting, so the carb may be gummed up.....orthe jetting could be wrong because you say it idles great but you smell gas and thepartial throttle you're getting a miss. And yes, replace the plugs & wires, as well as checking all the electrical connections.
Just my $0.02 though....
You have got the 'sportster cough'. If your lucky, it can dissappear. Try to adjust the air mixture screw. It is located underneath the carburator. Be sure the exhaust system isn't hot, take a small screwdriver to adjust the air screw a quarter, any direction. Ride your scoot warm and see how it reacts. If it the same (or worse), adjust the screw back to the beginning position and then a quarter in theother direction. This helps most of the times.
i just got the bike about 3 weeks ago and they guy i bought it from said it has been sitting at least all winter. ill give the seafoam a shot as well as adjusting the air mixture. i just picked up the plugs and wires and am going to put them in. ill let everyone know if any of this helps. and once again, thanks.
