Forward Controls
I am installing a new set of controls on My 01 Sporty and removing the old set, the right side where the bracket is screwed into the frame will not give for anything, I tried the Hex Socket but the end started to break apart, I have even tried a pipe wrench to remove it with no Luck. I am beginning to wonder if the threads are left handed. Has anyone had this trouble before. I am removing the old forward controls due to being rusty.
I have been told all the bolts feel like they want to break off. I think they are all lock tighted in. I took mine into the shop for that reason. Mine is in the shop right now getting the engine chromed and forward controls installed. The last thing I wanted to do was pay the dealer to do it, but I was more afraid of breaking a bolt off. I'm fairly certain there not reverse threads, just practically welded in. Good Luck...
I got the retaining clips off and got the left side off, it was a lil tough but not too bad that it would not come loose but the right side is being a "BITCH", I cannot get it to come loose for anything, I know they are not left handed threads but it did cross my mind, I will keep trying.
I may wind up with some Heat on it to Help break it Loose.
Had problems getting my mids off to put on new forwards. Wound up tapping bolts with hammer, then spraying with Bolt Buster loosener then tapping and ultimately putting a piece of pipe over the end of my socket wrench and pounding it with a hammer untill if finally budgedthen while hanging onto the bike pulling back towards it. It was a chore more especially on the exhaust side of the bike.
Just pulled out my set of old mids to look over the bolts. Looks like some white locktite at the end of the threads and a whole lotta black dirt/grease all over in the threads. And I remember clearly the side that was the biggest problem was the right side and trying to get enough leverage on it with pipe over my socket wrench and enough space to tap it with hammer underneath my exhaust. Was just hoping the pounding plus extra leverage didn't snap off the bolts.
