No Oil Pressure
Old 05-19-2008 | 05:00 AM
davetech4life's Avatar
davetech4life
Stage II
Default No Oil Pressure
I'm new to this post, and I was wondering if anyone has had this problem, and can guide me as to what to look for?
I have a 1979 XLS that was in storage for three years and did an oil replacement job with SAE50 the other day,
I went for a ride when the bike overheated after about 4 miles. I took off the return oil hose to the oil tank and while
running had no oil comming out.
I then went to the oil cooler inlet hose and again no oil comming out.
I'm not sure what to do next?
Old 05-19-2008 | 08:15 AM
Binny's Avatar
Binny
Default RE: No Oil Pressure
.....I know the IH forum guys could help you.......anything coming out on the pump on the bot rt. of your bike???...like I said , there are some good techs in the IH forum......the pump is an easy change on 78 and up models...B
Old 05-19-2008 | 09:21 AM
davetech4life
Stage II
binny, thanks for the quick reply. I'm going to take a look at the bike later tonight and see if there's a leak from oil pump area, i dont think there is one...but i'll take a look anyway. What is the IH forum??
Thanks again
Dave
Old 05-19-2008 | 09:36 AM
drum412's Avatar
drum412
Why are you using straight 50. Try 20w50, it's thinner when cold. Straight 50 may be to to thick to flow properly until it gets heated up. Although you should still get a little flow. So check out the oil pump also, and make sure you have a new filter too incase the old one is blocked up.
Old 05-19-2008 | 09:38 AM
Binny's Avatar
Binny
best to take the pump off the bike and make sure the gears are alright...should not take too long....I'm not an expert, but I hope this helps ya..I've owned a few IH's , and have had faulty pumps at times.......B
Thanks again
Dave
[/quote]
Old 05-19-2008 | 11:46 AM
liddown's Avatar
liddown
What is the IH forum?? It is the Iron Head Forum which is a sub forum to the Classic forum...
Old 05-19-2008 | 11:52 AM
Binny's Avatar
Binny
.yes....B.
ORIGINAL: liddown
baldy59
Shovelhead
06-24-2017 12:18 PM
TStephen
04-24-2017 11:39 AM
DavidStiebel
12-13-2015 10:07 AM
Sterling Nicholson
Oil Archive (no new posts)
09-09-2015 07:59 AM
harleyjohn45
Flathead
07-13-2010 11:38 PM
Quick Reply: No Oil Pressure
