Hesitation when I try to accelerate. Low on gas?
Old 05-16-2008 | 08:41 PM
nickydenick's Avatar
nickydenick
Default Hesitation when I try to accelerate. Low on gas?
I was waiting at the light and when it turned green, I accelerated as usual, but the bike hesitated, and I have to accelerate very slowly so that it will even out and move smoothly; in a way, it’s like there is not enough gas or something. It happened at 3 different lights. When I fill it up, it took only 2.2 gal, so I don’t think I was that low on gas (was I?), but the issue went away immediately. Any idea what I should look for before calling the stealership?
Old 05-16-2008 | 09:38 PM
bmkshort's Avatar
bmkshort
Default RE: Hesitation when I try to accelerate. Low on gas?
Can't say for sure but just for shitz and giggles, try loosening the fuel cap next time and see if that helps.
It kinda sounds like a vent issue.
Old 05-16-2008 | 09:43 PM
chaos5's Avatar
chaos5
Its fuel injected... If you had a carb I would blame dirt, but a brand new fuel injected engine shouldn’t be having these issues.
Maybe you should take it to the dealer and have them do their thing. It may have stored some error codes or something.
Old 05-16-2008 | 10:06 PM
SpursDarkrider's Avatar
SpursDarkrider
theres a thread that takes you to a link that details how to access the error codes, do a search
Old 05-17-2008 | 08:26 AM
SportyPig's Avatar
SportyPig
Could have just been some bad gas. Might have some water in the tank, and it only came into play once the fuel level got low. Maybe add some gas dry to the tank. Personally, I wouldn't do anything, unless the problem re-occurs.
Old 05-17-2008 | 09:25 AM
tweakin's Avatar
tweakin
Have you done any mods, like a PCIII?
If so there could be some fuel table adjustment needed.
Old 05-17-2008 | 12:27 PM
nickydenick
Actually, this is the second time in this month. When it happened the first time, I thought it could be bad gas from costco or maybe just low on gas. But when I fill it up, it took only 2.2 gal then. So, I concluded that it was bad gas from costco, now, I used only shell or chevron. Anyway, I do not have PCIII on it, pretty much a stock with SE pipe and SE sparkplug. Also, I don't recall it spit out any error code when it happens.
Water in the tank? hmmm.. is that possible?
Old 05-17-2008 | 01:22 PM
DannyZ71's Avatar
DannyZ71
It's always possible. Condensation in the tank itself, or in the gas itself from where you bought it. More than likely though, there is a vent problem. I'm not familiar enough with the new bikes, but used to be, there was an overflow tube. If there is such a thing on these new bikes, I'd look to make sure it's not kinked. Also, water could have gotten into/onto your air filter. Any chance that you washed the bike just before it happened?
There's quite a few possibilities. I'd take it to the dealer and explain what happened and have them run a diagnostic on it. That's the easiest and fastest way to find out.
Old 05-18-2008 | 01:45 PM
nickydenick
Thanks for the feedback.
Went to stealership yesterday to explain a bit plus the free hotdog and drink for their cars/bikes event. Also made an appointment with them next week for them to look at it. Hopefully, I will get some real/useful answer.
Old 05-18-2008 | 03:38 PM
gambler109's Avatar
gambler109
Cosco Gas..... That sounds like the problem. I don't care what people say, the low cost gas has never worked as well as the big names in my bike or car.
Quick Reply: Hesitation when I try to accelerate. Low on gas?
