Crankshaft Sensor
Crankshaft Sensor
I have a 2005 883L sportster, has anybody else had trouble with the crankshaft sensor?
Symptoms - engine warmed up, nice run at 50 - 60mph for six or seven miles slow down to a stop engine idling fine, open the throttle and nothing, just back firing, engine will not rev passed idle, after a couple of minutes able to pull away again after time the problem gets worse. The engine light comes on breifly so I did a speedo diagnostic, only code to come up was a faulty crankshaft sensor.
So I fitted a new sensor and this seemed to solve the problem (for two or three months)just had the same problem. Ordered two this time, maybe I just picked a bad spare.`
I also considered if temp was effecting the sensor so I changed to Mobil 1, a few guys had mentioned in previous posts that they experienced a temp drop, maybe this will help.
Waiting on the sensors to arrive before riding again, little nervous about breaking down altogether, it's a heavy bike to push!
Also I did check for manifold leaks and made sure the carb piston was moving.
I live in Barbados, not a Harley Tech in sight, so its just me and the Sportster.
