Question for all.............(I need help)
I sold my good friend my 04 1200C Sportster last year to get my Night Train. I loved the bike but just wanted something different. The question I have now is about my old Sporty. He is having problems with the bike, It keeps on going off while riding. When you first start it the yellow (starter/fuel pump??) light comes on for a second and then the power all goes off. If you touch the wires on the left side battery cover it come back on and off. I got it to start tonight but while I was riding around the block the yellow (starter/fuel pump??) light came on and then the power went off for the entire bike.
I know this is a long post but was wondering if anyone has ANY ideas on this problem before he brings it into the dealer to get checked out.
I really appreciate any help.
Thanks alot
Thanks alot
RE: Question for all.............(I need help)
Sounds like a problem with the battery post or the connection to the post. Take the cables off, clean them real good and put them back on with a little grease or vasoline on the post and connectors. If that doesn't help, have the battery tested.
Regards,
Bill
Regards,
Bill
Could be a battery post problem like Bill says, but is it the positive or negative wire you're "jiggling" at the battery? Depending on which one, it could indicate other things. Are both securely tightened on the battery? If you're "jiggling" the negative, is the other end firmly grounded (the negative cables have been known to be poorly put together on top of being a "smidge" too short)?
Thumper26
Thumper26
ORIGINAL: SoCal Harley
Thanks for all the great replies. I will be heading over my friends house on sat. morning to give him a hand and then we can go for a ride.
thanks again!
thanks again!
post back with yer results
Well I got a chance to check on his bike...............I cleaned up all terminals and wires. put the battery on a charger and it was all charged up correctly. Put everything back together and tried to start and all i got was alot of clicking. Sop I am guessing the starter is no good???? Any ideas before he takes it into the stealer?
thanks for all the replies again!
