Ramflo air filter
Ramflo air filter
Any body use or heard of the Ramflo air filter for Sportsters? The web site is www.trak-tek.com
Tim
Tim
RE: Ramflo air filter
Trak-Tek is a GREAT company, and the RamFLO is a really nice functional product.
A lot of people love the look - and if you do you won't find a better A/C... I personally like the ham can or else I would be running a RamFLO.
The people at Trak Tek are standup, and you should have no worries or quarrels about using them.
Also, I think they are the main distributor for RamFLO... so you'd be ordering from the right place...
Hope this helps.
Hope this helps.
No I have not changed the AC setup yet, but will proabally go with the Ramflo. Saw a post on someone who tapped into the the top of the breather bolts, inside the AC cover, then ran rubber lines outside the AC to a filter. He tapped a set screw into the end of the breather bolt to seal it. This way it functioned as a crossover but was concealed. I looked for the site but could not find it. Tim
I was thinking of tapping the bolts myself, kinda tired of the oil film.
My thoughts were to shorten the tubes a little and tap into the front and run lines to the bottom of the frame.
Its not so bad until I'm on the freeway, then it makes the list of things that suck.
If and when I do I'll let you know how it works out.
Well I ordered it yesterday! Suppose to handle 400cfm. Don't think my Sporty will have any problems! When I get it on I will post some pics and tell ya'll how it went. Chris was real helpful over the phone with info and answers. Apparently nice folk to deal with. Tim
