Disassembling bullet front turn signal?
I'm gonna be re-locating my front signals to the triple tree, and, of course, the instructions start with "remove gas tank". I'd prefer not to do that so... if I could detach the wires from the signals, re-route them, and re-attach 'em, that would be way better. Before I just dive in... anyone taken these things apart? TIA
RE: Disassembling bullet front turn signal?
The reason they ask you to remove the tank because the wiring harness goes under the tank, the sockets are right there, if you don't want to pull it out, I bet you can remove the front tank mounting bolt and lift it up a bit to get access. If you find a better way, please let us know.
ORIGINAL: 128auto
First off throw that paper away NOW !!
harley has a bad way of telling you to do this and that!
here you go
1-remove light from handybar
2-unscrew that pin or stud mount (sounds hellish)
3-place new mount over light and install with hiddin bolt
4-then remove lower tree bolt and install mount (torque please)
5-there is plenty of wire therewithout removing the tank
6-any ? please feel free to shout
here you go
ORIGINAL: RATROD HOG
here you go
5-there is plenty of wire there without removing the tank
here you go
You can remove the wires from the socket the bulb screws into. Study the wiring a bit, and I think the manual will show you as well, but you can literally pop the wires out of the socket make your changes and reinstall. Just draw yourself a picture showing which wire came from which side. I relocated my bullet t/s housing to the bottom side of the driving lights using this method.
After you've done one, it really is pretty easy!
ORIGINAL: Spartanden
