What size Torque wrench do you use?
Old 05-08-2008 | 10:15 AM
Demonsmasher's Avatar
Demonsmasher
Default What size Torque wrench do you use?
Looking to getting a couple Torque wrenches. What size of wrench do yall use? 1/4, 3/8, 1/2 ???????? I'm going to get one in in. lbs and foot lbs.
Old 05-08-2008 | 11:01 AM
Biker Trash's Avatar
Biker Trash
Default RE: What size Torque wrench do you use?
3/8 works fine for anything I need to torque.
Old 05-08-2008 | 11:02 AM
Thumper26's Avatar
Thumper26
I use 3/8" torque wrenches in both in./lbs. and ft./lbs.- most of my sockets and deep sockets are 3/8" and I really don't see a need for 1/2" for the work I am likely and willing to do.
Old 05-08-2008 | 11:29 AM
Stefan's Avatar
Stefan
You need a 1" for the 190-210 ft-lb nut on the mainshaft when changing out your rotor or stator, therwise 3/8", you can get 1/4 to 3/8 adapters for any sockets that are 1/4 & require in-lb torque.
Old 05-08-2008 | 12:23 PM
liddown's Avatar
liddown
Same here... 3/8, can go up or down with adapters.... Both of mine (In and Lbs) are SK brand good middle to upper brand....
Old 05-08-2008 | 01:35 PM
Ric27's Avatar
Ric27
You can do it all with one 3/8 5-80lb wrench. Just factor 12"#=1'# beyond that get a 1/2' that goes as high as you need.
Old 05-08-2008 | 02:42 PM
hogsport's Avatar
hogsport
I got 1/4" in lb 3/8" ft lb - both clickers and 1/2" guage $15 each at Harbor Freight. Yea I know - They are cheap Chinese s***, but so am I (but not chinese)
Old 05-08-2008 | 02:49 PM
SportyPig's Avatar
SportyPig
I use 1/2" ft/lb and 1/4"in lbs. Then use adapters if needed.
Old 05-08-2008 | 02:50 PM
kelton3's Avatar
kelton3
I recently bought a 1/4" in. lbs. from Harbor Freight. Before I applied it to my bike, I tested this on a bolt already on some exercise equipment. I set it around 80 in. lbs. I kept applying more and more pressure, the metal which the bolt was attached to actually started to bend. This thing wouldn't click! Then I said #$# it, and applied a great deal of pressure, then it became disengaged and clicked about 20 times. I took it back.
Old 05-08-2008 | 03:58 PM
running back's Avatar
running back
1/2 inch works good for the rear axle, 3/8 works good for inch #s.
Quick Reply: What size Torque wrench do you use?
