Fuel Tank Leaking / Coatings?
My tank is leaking, either from a seam or pin hole in the back by the seat. I'm looking at this
http://www.kbs-coatings.com/KBS-Cycl...it_p_7-31.html
The tutorial seams pretty straight forward. I'm not painting my tank! I will take the precautions to protect my finish. So will this be fine or does anyone have a horror story about this product or other suggestions?
RE: Fuel Tank Leaking / Coatings?
Just had this same problem, I bet you it is leaking at the rear tank mount. I used a product called POR-15, of all the products I researched, this one seemed to have the best results. Get the complete kit that has a cleaner, rust remover, and the sealer. Had mine back together for two weeks and it's still dry so far.
