running rich?
running rich?
hi,
i just bought a 2007 xl1200c with 2040 miles on it. My question is the engine always seems to be "lugging". it has se slipons with the fiberglass material removed. sometimes backfires through the exhaust on deceleration. and sometimes puffs a little black smoke when first started, this is my first harley and first fuel injected bike so i dont really know where to start looking.
thanks,
Allen
thanks,
Allen
RE: running rich?
mine has a puff of black smoke and loud pop when starting warm. I know mine is running slightly rich.
check your plugs, if there all black than yea your rich.
pop on decel is from gas buildup, it is another sign your running rich.
oh wait you said fuel injected?? take it to a shop and check the mixture.
or clean your air filter, might be clogged with a leaf or something
RE: running rich?
ORIGINAL: Lopoetve
i thought decel pop was running lean?
im pretty sure blue flames is lean, yellow flames are rich.
rich is cuased by gas buildup in the muffler, then igniting it with hot gasses also coming out. basically ignition inside the muffle instead of the cylinder.
lean is the flame front starting too late and the flame comes out when the exhuast valve opens, burning the valve and cuasing that combustion to exit and cuase a pop at the end of the pipe.
usually the rich backfires are louder than the lean ones purely becuase of the way it occurs
old skool1983
10-13-2009 10:27 AM
