Clutch Adjustment
Clutch Adjustment
Need to do 5k service I have the Factory service manual, and Fix My Hog Video, jack and necessary tools.
I hate to think of opening the clutch inspection cover to check the clutch adjustment.
Dealer did the 1 K and the adjustment was checked then, I don't ride hard is the adjustment all that necessary?
I do intend to change primary fluid.
RE: Clutch Adjustment
ORIGINAL: thomasf59
ORIGINAL: DPete
I always figured if your play at the lever remains the same not needing adjustment then nothing inside should need adjusting. Is that wrong?
I have only adjusted my clutch once. I think that was at the 15,000 mile service. I did adjust it several times around 25,000 miles, but adjustment wasn't the problem then. The Spring plate had totally come apart. And no, that wasn't due to a lack of maintenance to the clutch. Just a defective spring plate.
Just be careful with that quad ring, if you open up the derby cover. Those can be a real pain to get back in place if they come out.
HDF Tech
217
09-07-2023 09:07 AM
