I'm only going to make left turns..ugh
Old 05-04-2008, 10:56 AM
kawsakimx6's Avatar
kawsakimx6
kawsakimx6 is offline
Default RE: I'm only going to make left turns..ugh
ORIGINAL: ss377
3 lefts make a right. Once you get used to it, it will seem odd the other way. It took me a while to figure out how long to hold the button down so it wouldn't canceljust before making the turn.
how long is this?
  #32
Old 05-04-2008, 12:36 PM
CapnAdventure's Avatar
CapnAdventure
CapnAdventure is offline
ORIGINAL: Teek
I use the throttle lock occasionally just like OFG does...just not all the time, mostly on long rides on boring roads. But I don't set it so tight it can't be manually over ridden, or loosened easily while riding. I also noticed that when I throttle down I do NOT let the spring dictate my actions, so using the throttle lock is safe used like OFG suggested.I just wished it was more of a "lever" type mechanism instead of the star wheel.
The turn signals on either side took some getting used to. I thought it was peculiar and the other bikes using it on the left side only I think are more "intuitive". But then I thought about it. Having the signals onboth sides allows Harleys to have emergency flashers! Just push both signals at the same time, and you have hazard lights. I used them at my first Patriot Guard mission yesterday, and again coming back when me and the other guy I was riding with had to pull over on the side of the road temporarily. I'm used to the turn signals now, and I have small hands with short fingers and thumbs.
I use hand signals occasionally, but I'm fully aware that the vehicle behind me probably doesn't know what the hell I'm doing, so I use turn signals mostly.
Teek
Great point on the hazards, Teek. The other day after after making a delivery to Queenstown, Md., I ran into a rain storm. Because of the low visibility from road spray on US 50, I used the hazards to make myself more visible to those hi-ballin truckers and other assorted yahoos. Worked like a charm.
[IMG]local://upfiles/48168/DC9B1336B48547C0B14765097C5967AC.jpg[/IMG]
  #33
Old 05-06-2008, 01:37 AM
Teek's Avatar
Teek
Teek is offline
ORIGINAL: cHarley
Try the Throttle Mate lever, it works great, especially with gloves on.
http://throttlemate.com/
Thanks! That seems to be perfect! I saved it to my favorites so I won't forget to call them, or lose the website. Wish they had online ordering, but talking to a live body can be better! It's a lot better and cheaper than the Vista Cruise plastic contraption I had on the Honda. It worked well, though. Yeah, I'm gonna try out the Throttle mate.
Teek
jd2018
08-21-2018 07:46 PM
zeus33
09-28-2009 10:07 PM
jefnightrain
04-22-2008 01:02 PM
One_Lost_Hippie
04-04-2007 11:25 PM
anubisss
11-22-2006 09:25 PM
Quick Reply: I'm only going to make left turns..ugh
