relocating coil
RE: relocating coil
My kit (Ultima) came with the tank and some hardware to mount the tank. No intructions for relocating anything or even how to mount the tank and hardware. It wasn't too bad to figure out. On your kit did you mount the coil off the upper engine bracket where the horn goes? That's the only place I can figure to put it (close to the sparkplugs).
RE: relocating coil
ORIGINAL: Zimbob
the tank kit that i got moved the coil down a bit with a bracket that came in the kit. You just needed real small hands to get it mounted, what a pain in the butt.
A kit like this will work for ya but if I remember correctly they can be had at the stealer for about $18.00 http://www.heritagecycleworks.com/c56688p9703521.2.html
You may wanna print and take the pic with you as many of the **** suckers behind the parts counters don't know what the hell a coil/ignition relocation kit is.... had a buddy of mine get treated like an idiot when he was asking for one.... I had to grab the custom chrome book away from the "clerk" (that's all that parts guy was in my book), find the item and point it out to him.
RE: relocating coil
I already fitted my new tank and instead of buying the relocation kit, I put a 2 inch lift on the front of the tank and everything gets to stay in it's origional location. I made my own lifters out of 1 in. x 1/4 in. flat stock. Drilled one hole for the frame mount and drilled and tapped the hole for the tank mount. Idon't even have to use the U-shaped bracket that came with the tank either.
RE: relocating coil
ORIGINAL: Gpsjr10
Traces72
04-20-2013 10:15 PM
