shift lever selector does not select
Old 04-27-2008, 01:35 AM
fergerburger's Avatar
fergerburger
fergerburger is offline
Default shift lever selector does not select
I have a 1971 XLCH and the shift leverrotates about 1/4 turn but does not engage the tranny. I've never done a transmission so this is new to me. I looked at the shift selector rod in catalogs and it looks like it has a lever on the end with a small ball on it. I would guess this moves a drum or something (pawl carrier?). It feels like this is either broke off or the part it levers is broke. I'm guessing I need to pull the trap door...right? What kind of a mess will this be? I've rebuilt a good number of motors but always stayed away from trannys.
Old 04-28-2008, 10:11 PM
6o66er's Avatar
6o66er
6o66er is offline
Default RE: shift lever selector does not select
It's a pain in the *** on an Ironhead...but you're 100% correct on the problem.
I've broken 2 in the past year....it sucks.
You won't need to pull the outer primary completely, just loose the clutch pack and you should be able to access it easily.
Make sure you find the rest of it....and good luck.
TSheff
09-29-2021 02:18 PM
ThorpeFLH
04-03-2013 08:20 PM
Loco
08-18-2012 01:58 AM
thelawnmowerman
11-18-2011 04:09 PM
Babs
17
02-08-2007 10:48 AM
Quick Reply: shift lever selector does not select
