Funky noise
Funky noise
It's been going on for a while now. It's on the right side of the bike and I can't pin down where it's coming from, but it's a kind of clicking, clacking, almost scraping kind of noise. It's pretty steady/rythmic with the engine speed. You can hear it more when you're sitting at idle with the clutch disengaged and when you're going a slow speed in slightly high gear.
Engine oil is excellent but I haven't checked the primary oil. I thought it might be a heat shield coming loose but they're all on there pretty good. Any thoughts? If you have any questions or quick tips I'll try them out and get confirmation before I respond. Thanks
RE: Funky noise
You're talking about the clamps that hold the mufflers on? If so then that actually makes sense to change those clamps. It says that you have to change those after you take them off right? They're one time use only, well I didn't change them, I put the same ones back on after I changed out the mufflers.[sm=oopssign.gif] Well, I'll run the ole dealership and get two of those today I guess. I'll let you guys know.
RE: Funky noise
ORIGINAL: Kski
Just go to walmart and save yourself $20.
They are in the plumbing isle. If your Walmart is the same as mine... there are only 2 sizes. HUGE and smallish. Get the smallish ones.
