Hi, has anyone replaced their Handlebar Riser Bushings and if so, is it an easy task? A guy at the HD shop said one wire will always break and have to be replaced, not sure what this wire is. I'm a novice mechanic, but I may be able to do this one if it doesn't require a lot of disassembly. Thanks for all the help.
It is the ground wire underneath the right bushing (as you are sitting on the bike). No biggie, strip it, crimp on a new end or solder it back on the the ring that it broke off of. No trouble.
