HD Engine Guard or Lindby Multibar
As a new rider, I will feel more comfortable if I get a guard for my bike. The Lindby looks like the extended rests on top could be good for extended highway cruising and stretching your legs out, though I will probably stick to the backroads until I feel like I know what I am doing with the bike, so this may not be a real selling point for me at this time.
Does anyone have any opinions on one of these as opposed to the other? Has anyone had one and switched to the other? If so, why?
My ride is a 2007 1200C.
Thanks in advance for your comments!
RE: HD Engine Guard or Lindby Multibar
I put the Lindy on the wife's 883... nice bar, looks great, but at 5'5" she can't reach the bar comfortably. So she doesn't use it.... Although when she did a standing drop it sure saved the bike, doing a slow roll down onto the side... I was impressed with the way it protected her and the bike. For me, I didn't like how close it was to the forwards. My toes constanlty hit the lower part of the bar. Course I"m 6'1" and the forwards are too close for my liking, which is why I run with my 5" extended forwards... no need for highway bar..
My wife has a Lindby Multibar on her Sportster and I have onmy Dyna. Good strong bar but bigger than the HD oval bar.
Look around you can find them cheaper than $300.
http://cgi.ebay.com/ebaymotors/Lindb...QQcmdZViewItem
The Lindby Multibar is probably the best looking engine guard out there. Great for mounting out-facing hwy pegs. Mine is mounted on an '06 FXDWG. The only problem I have, and I think it's probably a design problem, is that at the point when the big twin goes through the RPM range that induces harmonic vibration (at some point in each gear), the Multibar vibrates like a rattlesnake. The problem is that the bar is designed only on one plane, which is conducive to vibration. If the bar had some bends in it that were not all on the same plane, the bar could not vibrate. I wouldn't buy this bar again.
**Update to this post - the Multibar broke at the lower mounting point, where the flat plate (welded to the tubing) was bolted to the other piece of flat plate behind the stock peg mounts. Anyway, lasted two years....it's junk now.....
doc_cj
08-13-2007 12:42 PM
