Help lowering the back end 2006 Sportster
I am running 10 inch struts which I like the look of and how much it lowers my bike. But I am tired of the wabble in curves, especially when hitting curves at 60+.
I cannot find any shorter shocks fora rubber mounted Sportster. I found a couple of 1 inch lowering kits, but I would rather lower it more than that if possible.
How did you lower your Sportster?
RE: Help lowering the back end 2006 Sportster
ORIGINAL: Golfgurl
don't know of anything else other than the lowering brackets... if you go lower, won't it hit bottom?
Lisa
Lisa
That wobble your talking about is the difference in rake/trail since you've dropped the rear more than 2" and the front remains stock hgt. thus affecting the trail, not to mention thestock front springs being spongy. Raise the tubes in the trees or lowering kit fork springs from progressive and I bet your handling will improve dramatically. By the way, I can guarantee that if you get 10-10.5" shocks you will bottom out on the wiring tube under the fender and your front end will still wander in the corners until you level it more.
Everytime I go outside and look at the Sportster and think of going back to shocks, I just feel sad. She looks so purty with the struts. Maybe I will stay with the struts a bit longer.
I was in the process of fabracating a set of 9-3/8 inch (shortest that are safe to ride). I might go ahead and finish them just in case I stay with the struts.
ORIGINAL: capttawes
So I need to drop the front end down? I kind of liked the front end up and back end low, but I will drop it an inch and give it a try.
