Should have just gotten chrome.....
Old 04-18-2008 | 09:43 PM
bhtx's Avatar
bhtx
Default Should have just gotten chrome.....
Then I wouldn't be so tempted to do what I just did.
I just took the rattle can to the lower engine, primary and stuff....It looks good so far. I will need to go back and cut in the small parts but should look good from a few feet away for now.
I was thinking about taking the dremel tool to the engine fins and seeing if I could get it to POP a little like the Night Train.
Any thoughts on that idea............?
Old 04-18-2008 | 10:21 PM
schumacher's Avatar
schumacher
Default RE: Should have just gotten chrome.....
pics! [8D]
Polishingthe fins sounds like a good idea
Old 04-18-2008 | 10:41 PM
Dallastx's Avatar
Dallastx
Yup!!! Post em!
Old 04-18-2008 | 10:51 PM
bhtx's Avatar
bhtx
I'll get some pics up tomorrow. Headin to the bar.
Old 04-19-2008 | 07:01 AM
Ribcracker's Avatar
Ribcracker
sounds good planing to go the same route on on My dyna and the sporty for the engine. PJ1 do a wrinkle finish high temp paint in a rattle can that works well then highlgith the fins with a dremel or mini da
Old 04-19-2008 | 08:40 AM
FandA M's Avatar
FandA M
Did you tear the motor down? (heads and barrels) If so it's real easy to polish the fins...... if not, it's more difficult to get to them all and get a consistant polish.I've done a few sets with a dremmel and they look great.The trick is to get them nice and flat without removing too much metal.If you're feeling daring youcan get a thin diamond bit and diamond cut the fins.It's not hard to do,just tedious.Cut in at45* angles(shallow cuts)on one fin and change the direction on the next and so on...........it takes a while but looks killer.
Also, to anyone planning on painting heads and barrels the standard wrinkle paint won't hold up as well as a high temp BBQ or stove paint(no primer).I've painted a few motors and have gotten the best results with BBQ paint(1200*)Ace Hardware makes an excellent high temp and it also comes in gloss black which looks more like a satin when cured.
Old 04-19-2008 | 10:09 AM
bhtx's Avatar
bhtx
yea, I just used the hi temp stuff from Home Depot. I will have to pull the motor to polish the fins so that will be later down the line.
moose1982
02-04-2020 03:46 AM
smurfsdad
12-10-2009 08:49 AM
AcadianBiker
07-15-2009 09:42 PM
screamn_eagle
04-14-2008 10:11 PM
chrskrngl
07-06-2007 07:53 PM
