signal colors
RE: signal colors
http://home.ama-cycle.org/amaccess/laws/result.asp?state=wi
It just says they are required, nothing about color.
RE: signal colors
Don't believe you can use blue at all. That color designates an emergency vehicle. Can use red on the back. but not on the front, also designates emergency vehicle. Doubt green would pass either. Your best bet is to contact the WI motor vehicle department. Nothing against what anubisss posted, but those are general guidelines. not the entire statute ofthe laws.
RE: signal colors
ORIGINAL: bobbsterkid7
I live in wisconsin and I am wondering if I have to have specific colors for signals or can I use something unconventional. I know amber is pretty standard, but could I use blue, or green?
Wantto giveJohnnyLaw a reasonto pull you?Go ahead and try blue or green and let us know what happens...
RE: signal colors
ORIGINAL: KSCruiser
+1
RE: signal colors
that's definately a negative on the blue...quick and easy route to getting a ticket.
and just go a head and call your local DMV...why would you want something other than amber or red? I'd be more worried of not getting the attention of someone with a less "flashy" light...i know it's only your turn signal, but that's the light you depend on for making sure that person that is right behind you realizes that you may be slowing down pretty soon.
RE: signal colors
After doing a bit of research... Sorry for big print but I copied and pasted this from http://www.aamva.org/aamva/DocumentD...EE42E8C9BD7%7D
This is Federal law for ANY motor vehicle.
Ø Hazard Warning lamps … operating all the
Turn signal lamps... At least 2 red or 2 amber
on the rear; 2 amber on the front; may also
operate the side marker lamps
