LOLLI FRICKIN POP
LOLLI FRICKIN POP
..Hey all.....there seems to be a mystery about the BCT "lollipop".....well, here it is......(this is headpipe baffle #2003).....will be installing on a customers bike, in conjunction w/ the Rushstraight thrudesign (basically all rush mufflers)......it looks simple and really not $80 worth looking, but they do really work well, and soundIMO awwwsome.......
So, here they are...and hell, ya get a free T-shirt, too.....late..................BINNY.......
[IMG]local://upfiles/54718/9F15C23424DA471DA1F569786381DF78.jpg[/IMG]
RE: LOLLI FRICKIN POP
I guess you'll get SOME result..................doubt it will be the same................How can it be the same???........talking apple and oranges here.............let me know, so I know WHAT SIZE bolt to use...........Thanks....BINNY......
ORIGINAL: LabCat
Can't I get the same results on my nightmarez by putting a bolt through the pipes?
ORIGINAL: Binny
ORIGINAL: LabCat
As state above, this is an old trick bikers have been using for years to be able to run drag pipes without losing all of the low end torque but retain most of the sound.
Here is a link explaining lollipops better.
https://www.hdforums.com/m_79533/tm.htm
ORIGINAL: Biker Trash
Mine is not a bolt but rather a circle with aline through it kinda like you'd see on a no fat chicks sticker. It actually creates enough backpressure to retain much of the bottom end torque without taking away from the sound. The lollipop is a bit different but can be made with a bolt and a washer welded to it in a perpendicular manner. You can shim it in or out depending on what your combination requires.In a nutshell the BCT baffles Binny displayeddo the same and take much of the guesswork and tuning out of theequation.
ORIGINAL: LabCat
Ric
I hear ya Ric. The time alone (since one hour of dyno tuning time is about $70 in the Milwaukee area) almost makes it worth buying the BCT baffles. That is why I bought and installed the torque rings you can see pictured in my Samson pipes. To save the headaches.
Not bashing anyone for buying the BCT baffles but clearing the air about the Lollipop mystery a bit. It's certainly not new technology as many seem to believe. Basically somebody puta little research into an old biker trick and was able to market it. More power to them.
The link I posted was one I had found a couple of years ago when I bought a set of 1 3/4" drags for my '96 (only to sell them before installing them). I hadn't looked at it for so long I forgotten it was an HDF link since I had found it before becoming a member of HDF.
