Metzler 880 Tires - Inflate to what pressure?
RE: Metzler 880 Tires - Inflate to what pressure?
ORIGINAL: Dallastx
Same.
Same.
Arod, again you do not list the year and model of your bike. Different models have different size tires & pressures.
Metzler tires run at higher recommended pressures than Dunlops. You can find the info. on page 21 of the attached Metzler pdf.
http://www.us.metzelermoto.com/media...twin_07_lo.pdf
ORIGINAL: cHarley
WRONG Answer Dallas. For someone that sells tires you should know better.
ORIGINAL: Dallastx
Same.
Same.
I run slightly higher (a pound or so) even than the recommended pressures that Metzler lists. Seems to work pretty well. I got over 15,000 miles on my first Metzler rear tire, and have over 17,000 miles on my first Metzler front tire. It still looks almost as good as new.
ORIGINAL: DPete
Hey, that sounds like good mileage Pig, I thought 880's were supposed to be softer with less mileage. Might have to get some when the time comes.
cHarley has it right. I run 46 PSI in the rear and 40 in the front with my Metzler ME 880 Marathons. That is the max for1 up and the min for 2 up light. Seems to be a happy medium in my case.
Also keep in mind there is a break in period of 200 Miles on the Metzler tires as stated on page 14 of the PDF cHarley posted.
slapshot12
04-19-2017 07:27 PM
