Oil cap fitting question
RE: Oil cap fitting question
The oil cap needs to be pushed down and turned slightly clockwise so that its form follows the contour of the oil-tank cover. It should fit flush with the cover. If you look closely at the cap andits receptacle you'll see how to properly insert it by the longer and shorter chase on either side of the cap.
It isn't flush yet. Put a little oil in the groves, get on top of it, grab it with a rag,twist it in as far as it will go, then press down on the cap to click it in. It should be flush. If it's not flush you may get a little oil past the cap. Crappy design, but that's how it is. Also, do not fill the oil past the half-way mark on the stick, measured hot. This also contributes to leakage and blow through the carb.
I had this same problem. I rode with it like this and oil actually came out. Press and turn (using a little muscle) clockwise until the cap screws in. It should be flush. Since I figured this out, i have not had any problems, however I ordered the oil temp cap.
Larkenem (05-19-2019)
Well I tried all of those things. Still the samething. I don't guess it hurts anything, wanted to see if I could get it down some then my thigh would not pop it all the time. I have use muscel to turn it, but I mean it is asfar as it will go with the groves, so it can't go no more.
