carb adjustments...
Old 03-31-2008 | 08:10 AM
capttawes's Avatar
capttawes
Default RE: carb adjustments...
Are you using the stock needle or other that is adj. withnothces, if adj. what notch is it set on? A needle set too high will give poor mileage and result in all of theother problems you mentioned. Try using 42/180 jets, adj. needle (use stock spring)with clip set on 3rd. or 4th notch from the top and fuel/air screw 2-2.5 turns out.
Old 03-31-2008 | 08:18 AM
cHarley's Avatar
cHarley
You also say the idle is still at 850. Why? Did you try adjusting the Idle speed screw to raise the RPM? (not the mixture screw)
You can't get a good adjustment on the mixture screw with the idle that low.
Old 03-31-2008 | 09:34 AM
brknisley's Avatar
brknisley
6th Gear
not sure on the needle,the idle i set by turning up the idle speed, then the mixture screw in until it seated, then backed out the idle speed until it stumbles.
Huggerbugger
05-04-2016 10:37 PM
gregjo1948
08-19-2015 07:22 AM
wils0720
Exhaust System Topics
09-07-2010 06:47 PM
mrb302
01-06-2008 01:02 PM
swodo
07-29-2005 01:20 PM
Quick Reply: carb adjustments...
