licks 10" short shocks
How much travel can I expect from licks 10" short shocks? I weigh in at 215 lbs. If you look at my other post, I am considering using flat stock to brace my rear fender off of the swing arm. Any thoughts? Also... could I cut and hinge the fender behind the stock bolt under the seat(using a piano hinge) allowing it to travel with the swingarm?
[IMG]local://upfiles/35163/407BE5E5328E4FB88969EA112B6312F8.jpg[/IMG]
[IMG]local://upfiles/35163/F1090470CCDA49C581DBED8CA042E0E3.jpg[/IMG]
RE: licks 10" short shocks
almost none....you're better off running either 11" shocks if you want suspension or going with rigid struts or a hardtail. 10" shortys don't do anything.
And if you mount your fender to the swingarm, it's independent of the frame, so it will always move with it.
TUCCI
01-22-2017 03:53 PM
