Brake problem
Brake problem
Trying to remove the rear brake caliper on a 93 883. I pulled the two bolts and pushed in on the caliper to retract the piston as the repair book says but the caliper comes up somewhat and then hits something solid and will not come up any further. What is going on. I even hit the caliper with a rubber mallet but it did not help. What is wrong??
RE: Brake problem
Dunno for sure if your bike is the same as mine, but I suspect they are fairly similar in design. To actually remove the rearcaliper on my Sportster, it is necessary to pull rear axle from wheel, and I believe there is another bolt that you have to remove to free it.
Give that a try
Give that a try
RE: Brake problem
Thats what im thinking. The caliper should come off and the pads still be on the bike. I have a manual and i did as the manual said. The caliper and the pads go on and off as seperate units. I must have a lip binding somewhere. The book shows it as a very simple project.
MEDEVAC247
01-13-2014 07:11 PM
