1200 Conversion 9.5 vs 10.1
RE: 1200 Conversion 9.5 vs 10.1
Blowing the top at 10:1? No way. The buell's come stock with 10:1. As for 9.5:1 vs. 10.0:1. The difference between them will be very little. 10:1 in theory should provide slightly better performance, but with half a point in compression difference it's not really a concern. On the other hand 9.5:1 should run cooler head tempertures: again with such a slight difference it's not really a concern. I am going to assume this is a street bike and not a high performance machine and you don't plan to do any furthur mods. If that is the case, then go with 9.5:1 if you live in a hotter climate and 10:1 if you live in a cooler climate.
My advice to you differs if you ever plan to go with high performance cams. Those usually have a long duration and you will need more static compression to get good cranking compression.
