Question about a Piston
Hey Guys,
Went for about a 160 mile ride today and came back and checked my plugs because I have been tuning with the sert. I took a mag-lite and looked down in the cylinder head. My piston is super clean around the outside, but right in the middle about the size of a quarter is some black, almost like carbon build up. Is that normal?
The plugs look good. This is my 08 883 with 650 miles on it.
Thanks
Jason
Thanks
Jason
RE: Question about a Piston
It's normal, but not desirable...a good way to get it out is to use Sea Foam in your next full tank and continue doing so once a month regularly. Flushes all the crap outta your heads. You may want to use 91 or better if you're not already. We have a couple places here to get 103 and 109 octane gas...it's AWESOME.
If there wasnt some carbon build up the I would be worried as running too lean the tops would be clean as a whistle.
Dont worry about it just give it a bit of throtle next run.
BTW do you take a torch and look up somewhere else after a big feed ???? residue has to sit somewhere.
Is it almost like carbon build up.... or is it a hole being burned in your pistion?
What does your exhaust pipes look like?
Do you idle higher/lower after tuning your sert...
You said you plugs looks good... what do they look like (color)...
All the things like this is important as to what direction (rich/lean) you're actually going...
Charlie D.
Charlie D.
TOMMYBLAZIN
Engine Mechanical Topics
11-28-2017 12:45 PM
