battery cover tin not staying latched
RE: battery cover tin not staying latched
ORIGINAL: nazareth27
yep same problem here. had my cover off so many times, and now have a bad front clip, im just gonna go replace it, maybe by a couple extra. havent had the cover fall off yet while riding , but dont want to tempt fate.
Personally I do not, and I would have to take the seat off to even begin to get a picture. Basically, you drill a small hole through the plastic clip. Hole small enough to allow the long part of the zip tie to go through, but small enough that the head of the zip tie won't go through. That will keep the cover in place. If you need to remove the cover, you don't need to cut anything. You just pull out the zip tie. And then put it back in once you re-install the battery cover.
I have a 06 1200c and had the same issue. This is actually a known issue with HD and is a recall notice. This will be worked on if you ever have the sporty in to a dealer.
The isuse is the clips wear out and loose their grip. I keep a spare set to replace when needed. they cost like 90 cents apiece.
The first time I had this issue us when the battery strap came loose and the battery pushed the cover off.
After numerous clip replacements, i went with trying to find a resolution. Not wanting to drill the cover, i added material to the area the clip engages. small strip on sheat metal, industrial adhesive and i was done. Area is thicker and the clip doesnt seep to stretch endlessly. Never had the problem again.
ORIGINAL: simpkinst
Hey, 07HD Nightster--glad your paint wasn't damaged when this happened to you--it's very nice.
And Sporty Pig, so sorry you lost your cover and couldn't find it--not fun! I like your pic and previously thought that maybe you were displaying such a warm gesture because you were so happy it was someone's wedding day (for reasons unkown :-)...but now I think it's because maybe you lost your battery cover on the way there ! And good advice to fix it anyway...
[IMG]local://upfiles/47766/5214AE2170444D64B23ED902C40D31EE.jpg[/IMG]
