Rear Brake Locks Up
Old 02-25-2008, 03:51 PM
BLKXL12C's Avatar
BLKXL12C
BLKXL12C is offline
Default RE: Rear Brake Locks Up
ORIGINAL: kidcrappr
Possible brake hose collapesing on the inside and stopping the caliper from backing off.
1 in about 2millon for this to happen, the DOT 5 fluid is not as harsh as the 4, if the rear is sticking it's time to replace the fluid on the front too stop this from happning there.
Old 02-25-2008, 03:54 PM
00ICUR12's Avatar
00ICUR12
00ICUR12 is offline
Brake fluid real old? Caliper pistons sticking? Moisture in the fluid will expand when it gets hot causing the pads topush harder onthe rotor creating more heat and more expansion.Sticking pistons can also cause the problem.From experience, when the caliper getsreal hot the seals will fail, brake fluid will get on the very hot rotor and the fluid does burn. Yup, nice little fire going on the side of the road in the middle of nowhere. Looked real funny removing shirtand using it to beat out the flames, but it worked. Yeah, the shirt was ruined.
Old 02-25-2008, 04:14 PM
DeJavu's Avatar
DeJavu
DeJavu is offline
I agree with a rebuild, however another cause could be the brakes just need to be bled. Air in the lines and trapped in the caliper itself, will expand with heat. In the best condition, the pads will be lightly touching the rotor, a little heat can start the reaction and cause the pads to be in harder contact til they lock up. Assure the piston is fully released, if not the return orifice can be blocked holding the brake on all the time. Good Luck!
Old 02-25-2008, 04:43 PM
mrb302's Avatar
mrb302
mrb302 is offline
Hearing that the bike has been sitting for so long, I'm going to agree with Biker Trash and cHarley (Why would you ever disagree with those two anyway?).
I'm betting the piston in that caliper is sticking and needs to be replaced/rebuilt. If you don't do so soon, the rotor will crack. Usually the cracks form between the cross-drilled holes in the rotor. Look it over real close and replace if nessasary.
Old 02-25-2008, 04:50 PM
BWLucky13's Avatar
BWLucky13
BWLucky13 is offline
A locked up rear wheel is one of the ugliest ways to die. Get it fixed.
2013superglideseattle
07-04-2015 12:25 AM
RidemyEVO
EVO
26
04-03-2012 09:57 PM
glidingwide
11-15-2010 11:08 AM
Silver Fox
07-03-2010 10:32 AM
carsoni
06-17-2007 10:04 PM
Quick Reply: Rear Brake Locks Up
