Questions about the fuel injected Sportsters
I just got a 2007 883C for my first bike and I have a couple of questions. I really want to put a set of Bassani Pro-Street pipes on it. I was talking with the assistant parts manager at the dealer where I got it and he told me that I would have to do more than just re-flash the computer. Is this true? If so what all would I need?
Also my dad has a Screaming Eagle Race Tuner CD for is Softail that he said I could use when they have to tune my bike for the exhaust. Anyone know if it will work on mine?
RE: Questions about the fuel injected Sportsters
I'm not an expert on the fuel infected bikes, but from what I understand the PC-III with the O2 eliminators seem to be the hot ticket. Also I have no experience with the company but others here have had great results getting it from http://www.fuelmotousa.com/since they offer free expert tech advice when setting the bike up.
The HD flash should work fine for just a stage one upgrade. I'm pretty sure you CANNOT use the SERT that your dad has. I read something about having to have the VIN in order to use it. maybe I'm wrong. I will second the PC III; I just got one from fuelmoto and the bike runs awesome.
ORIGINAL: RMT
yea what he said above,
I have a 2008 883 and have Rush slip ons and SE A/C and SERT. Once you use that SERT on a bike it gathers the VIN,etc. and it is with the bike forever. You will not use it on another bike. Like they said above, exhaust change should not need a remap period. That dealer remap is a joke, I wouldn't waste my money.
Well my plan is to eventually get a SE A/C but right now the bike is just way too quiet. I would rather do after market pipes like the Bassani Pro-Street or V&H Shortshots than a set of slip ons. So would something like the Bassani or V&H end up throwing a code? Would I need to get a set of MIL eliminators for it? I am coming from the car world so I am used to aftermarket exhaust ending up throwing a check engine light. This being my first bike this is still all somewhat new to me.
ORIGINAL: RMT
It may or may not throw a code with slip-ons but with a free flowing exhaust like bassani pro streets, it will probably run way lean (since it's already too lean from the factory thanks to the hippiesfrom the EPA)
If you plan on running a free flowing a/c than youneed todo a remap of some sort. I suggested a PC-III with O2 eliminators simply because you could save some$$ by buyingpipes for an 04-06 that don't have O2 bungs.
I have a question about this also. Every time I changed the air filter and exhaust on my trucks (89 S-10, 98 Ram Sport, and 01 Dakota R/T), the only thing I did was disconnect the batteryfor a while to dump the memory, then started it up and ran the crap out of it for a while so it could "learn" the new settings it wanted. Would that not work on these new bikes? (Last bike I had was a 1980 Low Rider bowling machine ((AMF)). It didn't have much in the way of electronics.
If you have to re-map, I would do the Stage I (air cleaner) at the same time. The expensive part is purchasing the SERT and having it dyno'ed and flashed. I had a 2007 Sportster that I put SE II Slip ons and SE Stage 1. They were able to re-flash with SERT without having to dyno. If you go with an odd ball setup that is not already in one of the supplied SERT tables they have to pick a map that they think is close and then dyno it and adjust the map for your bike. Don't want to go through all that twice.
On my 2007 FXSTC I went with Vance/Hines BS Staggered, SE Stage 1, and SERT. They put it on the dyno for that configuration as well.
