stock sportster running hot???
Greetings from Atlanta....after decades on an Ironhead, I just bought a 1200R (2008)...what a great bike....I am wondering about mods and some things the dealership told me.Has anyony had this mod done: Scream eagle a/c with the Scream eagle pipesw/ just the Stage 1 download and had some good/noticable performance from that???...also I was told that to pass emissions, HD sends thier bikes out runnning very lean, hence a very hot running motor, and the above mod I mentioned will still run hot.......is this true to the point of affecting longevity, and do they really run that hot???mine does not seem to.....dealer ship claims a race tune will take care of that, but that is big $$$$$$ as you know......what is your take on a power commander?..and then picking and chosing maybe some rush slipons and having a bit more versitiliy??.thanks, Robbie
RE: stock sportster running hot???
Do the SE pipes & A/C with the download and you will be good to go. The bike is lean from the factory but this should fix things right up without going overboard $$$ wise. (still not cheap though) I also recommend changing to a good synthetic oil at the 1000 mile service.
And Welcome.
And Welcome.
Borrow an infrared heat gun/thermometer and shoot the heads at the sparkplug right after riding it.....you don't want to see much over 300 degrees front/rear.
Mine's running 330 front 300 rear(just checked today)....I need to tweek the map on my PCIII to cool the front down a little.
ORIGINAL: SpursDarkrider
ok a newbie here, so im ignorant, how hot is "HOT"?
A petroleum based oil will start to fail at 250*. Synthetic oils are good to a bit over 300*.
ORIGINAL: YodaddyKeith
Thanks, and sorry for the interruption in the thread.
