Cable Lengths
Old 02-25-2008 | 03:08 AM
6o66er's Avatar
6o66er
Default RE: Cable Lengths
(Read above post first)
Here's a pic of my front end from a while back...notice the slack in the cable...this is ideal:
Old 02-25-2008 | 03:12 AM
thruster's Avatar
thruster
I suppose if it is too long I can always get a hose dude to shorten it for me.
Old 02-25-2008 | 03:15 AM
6o66er's Avatar
6o66er
Yep, I originally had 16" overall rise, so I went with a 48 and ended up choppin it to a 46 later on when I swapped for lower risers. It's not that big a deal, just make sure it's sealed. Your biggest concern is the T/I and clutch cables. That brake line could be 9 feet long and coiled under your trees, as long as that line is bled, it's gonna work, lol.
OH...and I think hardware stores like Home Depotor Ace Hardwarecan do the job...they make cables like that for water lines and stuff.
Old 02-25-2008 | 03:21 AM
thruster's Avatar
thruster
ok so if I go with the following I should be ok
44 3/4" throttle/idle
62" clutch
46" brake.
Is that a fair guesstimate. ?
Old 02-25-2008 | 03:29 AM
thruster's Avatar
thruster
it also appears the top agle is 60 degrees would that be correct (i am no expert) but it isnt 90
Old 02-25-2008 | 03:39 AM
6o66er's Avatar
6o66er
+6 on everything, and a 46" brake line should do it.
EDIT: you would actually use a 135(?) I believe that's the angle at the master cyl and a 90* at the caliper. Best to get one of each for both ends, though, that way you can mix and match to get a nice flow.
97HDSFTL
09-05-2018 06:34 AM
rugby2620
08-19-2013 07:23 AM
northeastconfederate
12-01-2012 10:26 AM
dcgray2
02-12-2011 07:09 AM
OneBlackFly
General Topics/Tech Tips
07-07-2008 04:48 PM
