Cable Lengths
RE: Cable Lengths
If you're working with 8" of rise and 40" end to end (I'm assuming these are drag-style...as anything else would look really silly on 8" risers), use a +4" set of cablesto be able to route it with the OEM guides and maintain a snug fit. You have to remember, with 12" mini apes on 4" Custom risers, that's a total of 16" of rise...you're only working with 8" if you're saying 4" over factory Custom risers. That more than compensates for the 40" end to end length.
You should have no problems at all with a +4 if you're looking to use your original path for running them. +6 may give you a bit too much slack.
RE: Cable Lengths
Brake line has been straightened and 1 clamp removed so it has no tension on it.
Throttle rerouted outside forks.
Clutch a tad tight and pulled against engine case
Pics of bars
Pics of bars
RE: Cable Lengths
Yeah, I'd be lookin to get a new set to run em back inside the forks...it's not as clean as-is.
If you order +4" over standard with 90* and 130* ends you'll be fine. Specially after seeing that pic. They should line up just right and you'll be able to route them neatly inside the forks again.
RE: Cable Lengths
I think I will get +6" to be safe and then I can use some billet clamps to neaten up the slack if need be.
It is a long way to Aus for shipping of cables to be just that bit tight.
So I reckon throttle +6 - Brake +6 and clutch well not to sure on that one and not sure if it runs inside the forks either as I looked at a mates low this arvo and his is outside standard.
RE: Cable Lengths
6o66er can you assit me a tad further please.
Ok I am still a bit confused about these cables so excuse my dumbness.
I want 6" over stock cables so I am assuming the bottom part number 0650-0609 is what I need for throttle/idle
First Image
For clutch I need part number 0652-0303 (close enough)
Second Image
BUt the brake has me stuffed.
They say the standard lenght is 42" (as below) is that correct as you said Barnetts reference was 35" ???
Third Image
Just need to get the brake sorted I think then I am all go.
cheers
Steve
[IMG]local://upfiles/35794/DA7100A409494ABEB34B6B405FCB7E30.gif[/IMG]
[IMG]local://upfiles/35794/B7EEC8DBAC1948EF9B806C3EDA910557.gif[/IMG]
[IMG]local://upfiles/35794/1A85A61452404389A0D6A3ED2D5834C5.gif[/IMG]
First Image
Second Image
Third Image
cheers
Steve
