Carbuerators
Carbuerators
I'm reading this site http://www.harley-performance.com/index.html
and i got to this page
http://www.harley-performance.com/cv-carburetor.html
it is saying pre-1989 had a two bolt flange to connect the carb to the manifold. and those carbs werent very good. but 1989 and after used a CV that was pushed into a rubbed boot stuck on the manifold and held by the AC. this is what i have. but my bike is a 1988
sportsters came out with the evo in 1986, i assumed a carb change came with it
is it just a typo on the site? or is my carb from another bike???
also, i was looking at this
http://www.harley-performance.com/stage-1-carb-kit.html
new jets, stock and bigger for stage 1 ACs and pipes, and a new needle, lighter spring, gasket, drill to remove mixture screw cover, and all that stuff. wondering if it is worth it? they say it can really improve performance of a stock carb. but according to the info on the site my carb isnt even stock hahaha
just asking your guys opinions
RE: Carbuerators
ORIGINAL: FandA M
Thats interesting.I thought all earlyEvo Sportsters had the spigot mounted CV carb(just pushes on) like you say you have.
The CV carb is actually a good carb and with those modsyou will probably notice thedifference.It could be worth itif your gonna do it yourself
but yea the model year thing is weird...
maybe they are trying to be general, like 1989 is when big twins went with the cv? and sportsters had it earlier?
RE: Carbuerators
I had a Mikuni HSR42 on mine for a while and it was a mess.Great carb but I had to make an extension for the intake manifold to clear the right side petcock soI could use it.I could barely get my fingers in there to turn the petcock.This was a spigot type like the stock CV's so I also had to make brackets keep it in place.It was a just a bad setup and real pain in the assso I finally got rid if it.I'm running an old SU now and I love it.Same principle as the stock CV carb and I've got plenty of room now.
[IMG]local://upfiles/36280/98A8507812AD4D2EACB67F228BAB0F77.jpg[/IMG]
RE: Carbuerators
Yeah......it definately sticks out pretty far but like what Jag said it's not a problem with mids.I use my hwy pegs alot too and believe it or not it's really not in the way.I ride like a slouch ,so that may have something to do with it too
JG: the carb kit you were looking at seems relatively cheap.Alot cheaper than a new carb anyway.I would definately give it a try
RE: Carbuerators
ORIGINAL: FandA M
RE: Carbuerators
ORIGINAL: LoneRyder
Um, am I seeing that right in that you have the crankcase bolts plugged??? No breathing??
ORIGINAL: FandA M
