wide glide upgrade....?
Remotely considering going a to an HHI 41mm wide glide with 3 deg. rake on my bike in the futureand was just wandering if anyone else here has one. Also what your thoughts are on it, pics, etc.
I see plenty of folks on the forums that have done a conversion using 39mm on mid or wide treesbut I'm thinking that if I go to the trouble and expense that I'm not keeping the stock legs and will go for new lowers and 41mm tubes.
Thanks for any feedback.
RE: wide glide upgrade....?
I tried to do that on an '07 model. Bought the stuff from a company that I won't deal with again. Anyway, since the Sportster frames changed in '04, the trees Ibought wouldn't work.
I ended up doing some "other stuff" to it instead.
What year is the one you are considering???
OldFenderGuy did a wide glide front on his I believe, and it looks great!
Yes, there are a few places that have kits that "fit a variety of bikes" but many require mods. or they just dont work. I'm looking at dealing with Hawg Halters as they have a great rep. in the custom parts industry and make trees and complete front ends made to fit sportsters.
OFG bike is cool but I'm not a long chopper fan I just want a little rake. OFG has a chopper kit from AME I think and its like 14 degrees, they make a 9 deg. also but thats still too much and those kits cost several hundred more than HHI.
Hey man, I went with the AME kit on my 04 and simply love it. I did pay the pretty penny, but the price would be the only down fall to the kit. You say you aren't looking for the "rake" look and that is cool too. There are several perks that come with the wide front end. One of the biggest is how it handles at real low speeds and higher speeds. It is true what they say about it tracking at 100mph without your hands on the handle bars.
BTW, how much trouble did you have with your speedo relocate?
ORIGINAL: hmurder73
Not sure if the question was for me, but if so, I didn't didn't have to reloate or modify the speedo location at all.....
With the 14 degree rake the front end will go from fork stop to fork stop and there is plenty of room between the speed and tank. (Around 5/8" to spare)... No problem removing the gas cap or anything...
I have heard that you might need to relocate the speed if you go with 18 degrees of additional rake, but I've never been able to verify that one way or the other...
I like the look of the stock riser/speedo, so if there was a problem I'd probably just have a spacer fabricated (and chromed) to place under the riser. A spacer of 1/2" or less should raise the speedo up higher, even with the 18 degree over setup.
