Warming up an 883 Custom
Old 02-09-2008 | 01:39 AM
thruster's Avatar
thruster
Default RE: Warming up an 883 Custom
Lean will make it run hotter and can cause more damage than running a bit rich.
Rather waste a bit of fuel than waste an engine.
Old 02-09-2008 | 01:50 AM
SportyPig's Avatar
SportyPig
My 06 883 was very similar with the stock pipes, air cleaner, and carb. Once I did the stage one, the warm up times are much shorter. It of couse depends on the temps. She still needs a good bit of warmup when it's 20 degrees outside, but not so much when 40 or warmer. I use full choke until I start to hear the "popcorn" sound. Then, go to half choke, which will get me to the "potato, potatoe, potato" sound. Ride for a half a mile or mile (depending again on the ambient temp) and then close the "choke".
Old 02-09-2008 | 01:56 AM
thruster's Avatar
thruster
Would you like a Pepsi with you popcorn and potatoes ??
Old 02-09-2008 | 05:57 AM
whaap's Avatar
whaap
I can't get over all the talk about "warming up" the bike before riding. I warm my bike up just as much as I warm up my car. I start it and ride off. My bike is an 05 1200 C so it is carbed but I have no need to set there and let it run. Once I'm underway I can have the choke all the way in within 1/2 mile.
Old 02-09-2008 | 10:05 AM
valveguide's Avatar
valveguide
I only choke/enrich to start the bike.
As soon as it is running that enricher **** is pushed back in.
Even if I have to sit on the bike for a while and only use the throttle to keep it going.
Sooner or later it is stable.
I would say ? 3 minutes tops before I can just let it alone.
Old 02-09-2008 | 10:16 AM
thomasf59's Avatar
thomasf59
I start it up, and go, usually take it easy for a few blocks depending on the temp.
Jmitch356
Carburetor Related
05-27-2014 08:13 PM
HDCrossbones09
01-17-2013 05:14 PM
bezzeghdenes
12-31-2010 09:51 AM
Kanzig
04-16-2008 12:20 PM
Quick Reply: Warming up an 883 Custom
