two carbs?
RE: two carbs?
You might be able to get away with a stock XR 1000 made back in '83 & 84 [8D]
http://adcache.cycletrader.com/5/8/1/81883981.htm
[IMG]local://upfiles/2665/B6B33B61849A478DBF6E16A9CA473785.jpg[/IMG]
RE: two carbs?
was watching biker bildoff sometime this past week - Alin ness's son was up against someone and one of the bikes had twin carbs - nesses had a three cylinder. laughed my ars off when the twin carb bike got only 32 miles before running out of gass - custom tank held a little ober a gallon - looked good though - ness won
RE: two carbs?
purefire: Use a stethoscope with a metal tube probe. Balance at idle and at about 2000 rpm. When they all sound alike when holding the tube about 1/2 inch into and perpendicular to the airstream at each carb, the carbs are about as synchronized as they are going to get. ......... BC
Chopster1200
10-27-2009 02:12 PM
carb, carbs, carburetor, davidson, harley, httpimg175imageshack, lawill, mert, mertlawwillcom, parts, ss, throat, trouble, xr, xr1000
