Pipes glowing cherry red???
Old 01-31-2008, 05:43 AM
dbleagle's Avatar
dbleagle
dbleagle is offline
Default RE: Pipes glowing cherry red???
Lean... late timing.... restricted exhaust....
Charlie D.
Old 01-31-2008, 06:51 AM
txoval's Avatar
txoval
txoval is offline
A late ignition timing causes the mixture to still be burning when the exhaust valve opens, heats the pipe red hot. A fuel mixture too rich can cause heating also, but usually fuel foul plug first. A burned exhaust valve can also cause heating
Either way I'd take it in to get checked out
Old 01-31-2008, 07:48 AM
Sporty07's Avatar
Sporty07
Sporty07 is offline
thanks i will take it in as soon as the weather is clear here....
Old 01-31-2008, 11:06 AM
Stefan's Avatar
Stefan
Stefan is offline
It's just running lean. That happens from using that download bandage instead of a SERT orsome other fuel management system.
Fuel infection just trying to trick the engine into blowing happy EPA numbers not caring that it's hurting the engine.
Old 01-31-2008, 11:17 AM
128auto's Avatar
128auto
128auto is offline
It could be ignition timing issue imo.
Old 01-31-2008, 11:25 AM
Sporty07's Avatar
Sporty07
Sporty07 is offline
i found out, from local mechanic that it is normal for pipes to get like that esp. at the head, now if it was further down pipe then i would have a problem, but he told me not to worry
Old 01-31-2008, 11:36 AM
Stefan's Avatar
Stefan
Stefan is offline
They should sell HD smokes now that you have pipes to light them with.
Old 01-31-2008, 11:53 AM
1200c's Avatar
1200c
1200c is offline
I have heard that, but I have never seen it happen. I would still look for problems.
Old 01-31-2008, 06:11 PM
txoval's Avatar
txoval
txoval is offline
If your pipes are turning red, you have a problem
Old 01-31-2008, 07:04 PM
HD7585's Avatar
HD7585
HD7585 is offline
Sitting still with no air flow..........This is normal at the head..........There is no problem..........My evo has done it since 84.......it can't be seen in bright light, but running while parked at night or in a shaded garage they will be red. Once you start moving, they cool down (air cooled engine)
Quick Reply: Pipes glowing cherry red???
