FOOT PEG REMOVAL
I have a new set of pegs to replace existing set. On the pin that goes through the pegs there is a split ring holding that in in place. I would like some suggestion on how the get that ring off without breaking or damagingit. Is there a special tool? I am in a very rural area but do have Napa / Autozone...
Also - have a solo seat and no need for rear pegs. 2 alan bolts holding peg fixtures to frame. Tried to get those bolts loose with no luck. any suggestions here?
Thanks
Thanks
There is a special tool. I got mine at Sears, I think its called Spring Clip Pliers. I've gotten them on and off without the special tool, but the tool does make it easier. I've run into problems with the clips deforming when I've taken them off, so I now keep a small stock of new ones, they are quite cheap and available at your HD dealer, maybe also at autozone.
Those rear peg bolts are on tight as a mother, with blue loctite. It would be eaiser if you could find you a set of allen sockets and use a long handle ratchet for the leverage but if all you have is a little L shaped allen wrench just find a piece of pipe that fits it snugly and use that as your leverage.
