Craftsman torque wrench For my 1200C
Just bought CRAFTSMAN Microtort Torque Wrench 3/8 drive In Lbs Any one use this wrench? I can"t figure out Selecter Numbers from0 through 14 on collar how they corralate to scalestamped on shaft25 to 250 IN LBS Only Example is in instruction book is 0-40=40IN LBS Any one use this what do u think of it .I have a beam FT LBS wrench works good but needed a IN LBS for a lot of Fastners on my 06 1200C
RE: Craftsman torque wrench For my 1200C
I bought that same wrench in Pierre, S.D. for this:
behind the motel. Worked fine. You can use your beam ft-lbs wrench. Jut multiply the reading by 12 to get inch lbs. I.E., 10 ft lbs = 120 inch lbs. I'll leave the dimensional analysis as an exercise for the reader.
I have one, it works fine. On the back side of the wrench shaft is a inch #'s scale numbered 25, 40, 55, 70, etc. (15 # increments). On the wrench collar is the numbers 0 - 14. Turning the handle until the number 0 on the collar lines up with the number 25 on the shaft = 25 in. lbs. If you continue to turn the handle until the number on the collar is 0 again you will see that it lines up with the 40 on the shaft, thus 40 in lbs, etc.
ORIGINAL: carlo
Just bought CRAFTSMAN Microtort Torque Wrench 3/8 drive In Lbs Any one use this wrench? I can"t figure out Selecter Numbers from0 through 14 on collar how they corralate to scalestamped on shaft...
It's a pretty good wrench. I'm a little mystified as to why you can set the ratchet mechanism to loosen a fastener. (You should never loosen a fastener with a torque wrench, only tighten it.)
